F34 - AC Overload - Software Update Suggestion - Turn Aux Loads Off
A suggestion to the developers of the firmware:
When experiencing a temporary overload situation F34, can you add a setting to turn off the Aux Load at Set Inverter Load, e.g. when Inverter Output Reaches 7500 W turn of Aux Load to prevent the F34 - AC Overload scenario?
Non-essential loads should be sacrificed in favor of essential loads.
In this way, the inverter can protect itself from overload as well as continue to supply power to essential loads.
