2x 5kW in parallel vs 2x Solar panel East and West string as input
Hi
Just need confirmation on best way to connect two solar panel strings (East facing = 9x 455W panels and West Facing = 8x 455W panels) to the 2x 5kW inverters setup as parallel inverters (master/slave).
Currently everything is working without any issues with the East string connected to the master inverter and the West string connected to the slave.
Question: is this the better setup or will it be better to connect both strings to the master inverter. Asking since I am not sure if it will make any difference.
Meinhard
Thanks.
I connected each string to 1x mppt per inverter.
Meinhard
