Life cycles of the SUNSYNK-L5.1?
Possibly a naive question, but what is the SUNSYNK-L5.1 rated to in terms of life cycles or life cycle power?
The SUN-BATT-5.32 manual states clearly it's rated for 6000 Cycles @ 80% DOD / 25ºC / 0.5C, 60% EOL. I can't find anything equivalent in the SUNSYNK-L5.1 manual. This retailer https://www.bimblesolar.com/Sunsynk-IP65-L5.1 cites >6000 cycles and 16MWh, but I'm concerned I can't find that on Sunsynk's own website.
Thanks,
Andy
Sunsynk are not ver good at documentation. You would expect them to at least be consistent so that you can compare products. If you did not know better, it lookslike different people write the manuals and no one reviews the quality and content of the documents. I have been hassling them about the lack of a simple document/data sheet to allow you to compare products, particular inverters and batteries.
Life cycles of any battery is a relative thing regardles of the specs. The specs are worst case scenario, while it is possible to discharge the battery to the extremes specified due to incorrect sizing of the battery or inverter configuration, it is unlikely that you would not beable to exceed the specs of the battery.
