danieldaniel
12 x 600W panels 8.8kw Sunsynk
Good day, new to the forum and new to Solar. I just installed a solar setup with 12 x 600W panels, 8.8kw Sunsynk inverter and 2 x 5.1 Hubble batteries. I'm trying to see what the panels are generating at any given moment, but the feed from the PV on the inverter only shows what it is currently pulling from the panels i.e. what is needed for the current load. Is there a way to see what the array is producing? I want to see what my array is producing, the array can generate 7.2kw but at midday if I add load to see where it peaks it currently seems to go to 5,6kw max with the rest then feeding from the batteries or grid.
Any help/guidance will be appreciated
Unknown member
Jun 06, 2022
@thebaps1 sorry for bugging again - I tried changing the setting in System 2 which was Zero Export + Limit to Load only to the Zero Export setting and then the PV value went up, but it also showed the supply being used by the load using almost all of that - but nothing in the house was consuming that much?Looking at the System Flow Chart screen on the SunSynk inverter it showeda negative value flowing in e.g. PV 4.4kw then load -4.0kw while the house was using 0.4kw - does that mean the output from the PV is 4.4kw and there is an excess of 4.0kw? Or am I reading that wrong and is that bad for the inverter to set it like that?
