Zero Export - Limit to Load
What is the difference between "Zero Export" and "Zero Export + Limit to Load" setting in the System Mode menu?
Hi All, if zero export ticked, the inverter will not export any power beyond the CT coil. The inverter will try and zero the reading at the Ct coil if surplus solar available or battery is discharged in terms of a schedule. If limit to load is also ticked, the machine will only use surplus battery and or solar to zero the reading of the load (essential circuit). Make sense?
