CT readings after grid return, before inverter connect is zero
I have an 8kW Sunsynk inverter with a 10kW Sunsynk battery.
I do not have any solar - at the moment - and i am not exporting to the grid.
I see that there are no CT readings on until the inverter has reconnected to the grid after a power outage.
Thus, when the grid return, and the non-essential loads strart using power, the ct will show 0W until the Inverter has reconnected to the grid.
Please update the firmware to reflect the Grid power consumption even if the inverter is not consuming any grid power.
Leon Botha
Jan 28, 2023
Hi jacekowski
I think you misunderstood my request. Please read the subject again. I know that when there is no grid the reading is 0.
I would like to have the ct reading during the time that the grid has returned, and the inverter has not connected back to the grid as well.
