Public·326 members
Sunsynk Hybrid Inverter - Battery problem
Hi
I have a new solar installation installed this week by a 3rd party. Their support has not got back to me, so I was hoping to get some input from you.
I hope you can be patient with me, as I am very new to this.
- Sunsynk Hybrid Auto inverter
- Synsynk 5.12KWh battery
- 4KW of panels
Everything seemed to work fine for the first 36 hours. The battery discharged to 20% overnight, then grid power was used for the house load until the sun came up. All good.
But I am now seeing erratic battery / grid behaviour, when the battery drops to 50V. Here is the diary of events since installation:
Day 1: battery fully drained as expected to 20% (51V) overnight. Then grid was used to power the small overnight load. - (as expected)
Day 2: battery only drained to 57% (50V), and then the inverter started pulling intermittently from the grid to keep the battery marginally above 57%(50V) - (not expected)
Day 3: battery fully drained as expected to 20% (51V) overnight. Then grid was used to power the small overnight load. - (as expected)
Day 4: battery only drained to 44% (50V), and then the inverter started pulling intermittently from the grid to keep the battery marginally above 44%(50V) - (not expected)
Last night's charts attached.
Battery settings attached.
It looks like the inverter is pulling grid power due to some battery issue around 50 volts, perhaps? I can see no setting that refers to this.
Can you advise - is this a settings issue or a battery issue?
Here are last nights charts - when the battery refused to discharge beyond 44%. The inverter used the grid to maintain the battery at this 44% level. The grid should never be used to charge the battery on this system.
Why is the battery being maintained at abitrary charge levels by grid power? Intermittently!
Like I say, this seems to happen at the batter 50 volty threshold (see charts above). But I don't know if that is a factor.
thanks
nikki@sunsynk.com
nikki@sunsynk.com
Aug 16, 2022
Thank You for your query , could you advise of your email address in order for us to assit you directly.
Should you require any further information please don’t hesitate to contact us at the Customer Service Helpdesk on 0151 832 4300 or alternatively email us at customerservices@sunsynk.com.
