How to cool the 3.6Kwh Inverter
As temperatures rise this week, so is the temperature of my inverter installed in my loft.
i have attached a graph of the temperatures reached so far (30 Degrees C today!!)
It has reached 59 Degrees, and being mindfull of the operationg temperature ranges i want to know what solutions are out there so that i can keep the inverter reasonably cool in this mini heatwave so that i can preserver its operational life and effectiveness.
You will see that at 17.00hrs the temperatures started to go down. This was a direct result of me placing a domestic fan infront of the inverter and in a small amount of time, its temperature dropped 10 Degrees!!
i am a little concerned in that i will not be the only person to see this and wondered how anybody else with a loft installation is dealing with this?
Thanks in advance
Chris
I have seen a few installers put 3 or 4 small pc fans next to the right hand side vents of the inverter, sucking air through. It works well.
