Public·262 members
Sunsynk (INVERTER) Something or someone is changing setting timers and mixing up mode settings. I'm on octopus flux tariff which I don't
Works and messes timestimes upup it's as if someone else is controlling it ..Need suggest to dodo . Help
ElectricMolehill
Apr 05, 2024
By default this will use timers to charge the battery from grid to 100% between 02:00 and 05:00 then change Work Mode to Selling First at 16:00 and export to grid until the battery reaches 40% (or whatever is set in the app). At 19:00 the Work Mode will change to Limited to Home. If you want to control the timers and Work Mode manually, change from Live Price mode to Hourly Price and add the prices. In this mode the app will not change inverter settings over the 24 hour cycle
  • Rokil Naro
    Rokil Naro
  • Арно Дориан
    Арно Дориан
