Generator connection on parallel 12kw 3phase inverters.
Hi guys, going to install three 12kw 3phase inverters in parallel. Can I wire the generator to all three inverters? I have a 80kva generator. I read somewhere that you can only wire it to the master inverter. Is this true? If so, is it just for the generator port? If I have a 25kw load and the grid goes down, surely you can't put the full load from the generator to just the master inverter? Any advice will be appreciated.
Karel
