SUNSYNK 8KW Inverters so that I make a 16kW single phase system?
Is it possible to couple 2 of these SUNSYNK 8KW Inverters so that I make a 16kW single phase system? If yes, Do I need to buy any coupling cards or additional equipment to combine the 2 inverters?
Yes you can up to 6 inverters can be wired together
Hi Keith,
please advise as to what hardware will be necessary in order to single phase parallel the 8kW units or if it is done just with settings as in the above manual you posted? I see a "Junction Box" on page 8 & 9, where do we purchase this?
