Any Solution for a 3 elevation PV system
Im new here. UK Based.
Is there a solution to using a Sunsynk unit + battery where I have PV panels on three different elevations?
(Front of house 5x 405W) + (Rear of House 5x 405w) + (Side of house 3x 405W)
Thank you.
1) Fit optimisers on the front and rear house strings and parallel them into a single MPPT input and use the second MPPT for the side string.
2) Connect one string to a separate AC couple inverter/micro inverter on grid side
3) Connect one string to a separate inverter/micro inverter connected to Sunsynk AUX input
