Parrallel Installation of 2 x 12KW Hybrid Inverters
we have just completed installation of 2 x 12KW Sunsynk Inverters (3 Phase). Each inverter is working well independently, but when we try the parallel config on both inverters we are getting an F29 error message.
We have followed the instructions for troubleshooting the problem as per : https://www.sunsynk.org/post/understanding-fault-codes
Switch off all inverters and reset them. Done
Check each inverter has the correct and same operating system. Done - OS is identical, but not sure if it is correct. (Software Version: 4790122526R)
Check the models are all the same. Done
Replace the communication cable with shorter cables if possible ensure that the middle inverter is the master and slaves or other inverters radiate from the centre inverter, this keeps the communication cable as short as possible. Done
Check the port limiting resistors are set correctly. Done (tried switching them ON/OFF)
Check all your batteries are on the same bus bar. Done
I have read somewhere that the Inverters may require a firmware upgrade, how do we go about this?
so our supplier has narrowed it down to updating the firmware. Will try that and see how it goes
