Public·324 members
Battery warning light
Hi
I have 4x5.12 batteries that 3 have started flashing a warning. Other than a value of 80 for warning1 under each of the batteries, I can’t work out what the issue is! In addition,the batteries seem to be mismatched as far as SOC is concerned, 1 being 13.6%, 2 at near 22% and the final one being 27.4%. Can anyone advise how I get these batteries to be more balanced?
Thanks, in advance, for your help
Gunn
gunn
Jan 16, 2025
Thank you for the advice - I did do that and it rectified the problem. My only issue is my settings aren’t allowing me to charge the batteries in my cheap night period, would you know what I need to change in the settings to allow more than approx 2.4KW to go to the 4 batteries. I’ve adjusted the batteries settings - charge amps from 40A to 60A and changed the grid charge amps from 40A to 60A but neither seem to have changed the rate the grid charges the batteries! I’ve 4 x 5.12 Sunsynk batteries with 2 each connected to a separate inverter. The inverters are correctly setup in master slave modes as are the batteries. The system worked fine with 2 batteries but does not work fully with the additional 2 batteries, ngence not charging to 100% regularly (if at all in winter!)
