Public·324 members
Gen Force tickbox?
Hi, yesterday I tried my small Ryobi 2600 generator on the Aux/Gen port of my 3.6 Sunsynk. Worked well, tho I limited gen charge to 5A, as the gennie needs some loving care. Didn't use it since, but today noticed that the green GEN bar on the main display showed 17.2 hrs runtime at 17:20, as if gennie is running continually, tho hasn't at all. What could cause this? I ticked Gen Force box on recommendation from someone - could that be the cause? BTW, In forum categories, the N is missing in Technical Support. It says: Techical Support
Welcome to the Sunsynk technical support forum .....
butalez
butalez
15 лист. 2022 р.
Does anyone have explanations of the 4 tickboxes regarding generator charging in the BATT CHARGE screen of the setup. Would like more info re: Gen Charge Gen Signal Signal ISLAND MODE GEN Force Also on Grid Charge side, what does the Grid Signal box do? I've on the latest firmware, the older firmware doesn't have all the same options
