❗ Bug - Power limit on system timer not working
Hi everyone.
So I have tested the power limit in the system timer on the 12kw 3 phase inverter and it only seems to work in some cases.
In the first scenario at 1pm I set the power limit to 0w between 12pm and 3pm however the inverter was still using 5.7kw from the battery.
Where the power limit has worked is in the evening when the inverter's time is after 10pm. Will post pictures of this later.
Not sure why this is happening. My system timer is in order and starts from 12am and ends at 12am on the last slot. I have tried different combinations of this and nothing works.
I am running the latest software as of 17/11/2022 which M 2005-1123 / S 18-07 / C 1001-E030
Update:
So I have gathered that the power limit on the system timer only works when there is little to no incoming PV. I have tested it at 7pm today and 10pm yesterday.
I will switch off the PV tomorrow morning and test.
