number of batteries
I have a sunsynk 3.6 hybrid inverter. i have 3 pylontech batteries the bigger ones 5.2? if i was to use the inverter just to manage/charge /discharge the batteries is the inverter big enough for the 15 odd kw battery bank.what will be the limitations of this system? Can the inverter only provide 3.6 kw to the load from the battery bank at any given time?
The only limitation is that 3.6kW power limit, so it will take long time to charge/discharge the batteries.
