Battery Volt vs SOC
Goodday. I have 2 SunSynk 8kW in parallel. When I set the battery to VOLT mode, I can only charge 30A to a 1000Ah lead-acid pack. If I change to SOC mode it almost immediately charge the pack with 160A.
Why are this happening, guess it is some setting I am missing.
My setup are as follow per inverter:
Hi It is better to use SOC settings for it will charge more effectively than Voltage settings.
