We had 2 batteries and one turned out to be faulty so it was replaced yesterday. I set the inverter to charge the batteries overnight but this morning they haven't charged at all. As far as I can see, no settings have been changed from our previous setup. I've set it to draw from the grid this afternoon but I don't think it will work. Can anyone suggest why it won't work? Pics of inverter system mode attached. Thanks in advance.
Change enerygy payern to Priority battery. Connect only 1 battery. Change battery settings accordinly. Charge battery full. Change to other battery. Charge to full. Conntect both batteries, if they have dipswitches set corectly. Change battery settings correctly. All should work, good luck😀
