Public·369 members
UK clock change still causing issues
Following the UK clock change the time zone is still not correct. I appear to have everything correct. Timezone is London, charging set to start at 00:30, but charging didn’t start until 01:30. When I look at thE latest graph data the time is correct (I.e it’s now 06:39, latest data on the graph will show 06:39) - so the time is correct)
Any ideas?
Riffman117
Mar 28, 2023
Just a heads up for anyone who did the same 'fix' as me to check what happened overnight. My system started charging at 1am, not 2am as intended, which suggests something happened in the background to bring the inverter clock back in line with the app. I've moved the charge times back to their usual setting, so hopefully tonight will see things start happening in the correct time slots again.
