Public·327 members
Bob Hopkins
Bob Hopkins
Wind turbine Can a small wind turbine be connected to charge the batteries
Jan 23, 2024
The short answer is yes. Setting up a turbine is a bit trick as you need to protect the turbine from runaway senarios. The SS inverter manual do have a good section on how to use a wind turbine (at least the 8Kw manual does)
