Maximum charging rate from grid.
I'm trying to charge my Solar MD 14,3 kWh battery on an 8kW Sunsynk inverter from the grid, but it seems to max out at about 2,6 kW of power going into the battery.
The battery charge amps is set to 150.
The Grid import power limiter setting is 850W... even when I change it and save, it reverts back to that value.
Grid amps is set to 120.
Any thoughts on why it won't charge any faster? I can't find any other settings that seem relevant.
Thank you.
Actually, the battery does discharge successfully to whatever level I set it to.
