Public·391 members
12volt power supply in 5kw sunsynk inverter?
Hi folks. I have just bought my 5kw inverter and 5.3kwh battery which is currently setup and running. I will be installing 8x 565w pv panels in a few days time, which should be plenty for my power needs.
Seeing as my inverter has no cooling fan, only an enormous heating at the back, I still have concerns of the inverter getting too hot when I have a high power usage. I have printed a cage for two 120mm pc fans to be mounted to the underside of the heatsink and provide a bit of extra cooling to the unit. I have read that some folk are getting tempretures above 60deg. To me that feels way to high. I was looking to see if there was a 12v power supply on the rail that the CT connects to, but it seems not.
I am wondering if anyone has done a similar thing and how have you powered your fans. Or is the inverter having high tempretures nothing to worry about.
Aug 08, 2024
Some inverters like the 8.8kW inverter do have a 12volt supply available, but the 5kW inverter does not. If you were to add the fans you would also need to get a temperature controller that will turn on the fans at the desired temperature so it is quite possible you will need a power source for this and this can double to supply power to the fans.
While the ambient temperature is recommended to be between -40~60ºC to ensure optimal operation, The heat sink will get much hotter.
However, there is no harm in adding some fans if you are concerned.
