Public·371 members
Ivan Brewis
Ivan Brewis
Inverter battery setup - Sunsynk LiFePO4 10.65 KWh SUN-BATT-10.65
Hi
I'm trying to establish "good" settings for my battery, whilst understanding the implications to battery lifetime of the different options given under the "battery settings" page.
I'd like to use the greatest "good" range of charge.
Various sources for this battery describe "100% Depth of Discharge"
I'm not sure what that would mean though on this setting page.
Would it be reasonable to set the "Shutdown" to 10% and what does shutdown mean? Does it mean I would loose control of the inverter below this value and need to manually reset as it seems to imply?
What would be good Discharge / Charge amps to use for a good battery lifespan?
Thanks!
Current settings look like this:
Unknown member
Apr 26, 2024
Hi Groots, thanks!
It isn't a concern that the battery is charging and then suddenly discharging again for a brief time and then charging again shortly thereafter?
