The Sunsynk website will be temporarily unavailable from Tuesday 5th May due to scheduled updates as we transition to an upgraded online platform.
Customer Support UK: +44 151 832 4300 | SA: +27 (0)10 1003589 | NL: +34 40 798 7136
Alternatively email support@sunsynk.com or get in touch via the Sunsynk Connect app.
30kW 3-Phase Hybrid Inverter
High Voltage
.jpg)
This is a multifunctional inverter, combining functions of inverter, solar charger and battery charger to offer uninterruptible power support with portable size. Its comprehensive LCD display offers user configurable and easy accessible button operation such as battery charging, AC/solar charging, and acceptable input voltage based on different applications.
A compact design and high-power density and saves device investment. It supports three-phase unbalanced output, extending the application scenarios.
100% unbalanced output (each phase)
AC couple to retrofit existing solar system
Max. 10 pcs parallel for on-grid and off-grid operation, supporting multiple batteries in parallel
Max. charging/discharging current of 100A
High voltage battery, higher efficiency
6 time periods for battery charging/discharging
Supports storing energy from diesel generators
