The Sunsynk website will be temporarily unavailable from Tuesday 5th May due to scheduled updates as we transition to an upgraded online platform.
Customer Support UK: +44 151 832 4300 | SA: +27 (0)10 1003589 | NL: +34 40 798 7136
Alternatively email support@sunsynk.com or get in touch via the Sunsynk Connect app.
Single-Phase String Inverters
5kW/10kW
The Sunsynk Single-Phase String Inverters are not only easy to install, but also allows for quick DC and AC connections. Commissioning is equally easy, because the integrated user interface (local LCD display and buttons) makes it possible to choose the necessary settings quickly.
Single-Phase String Inverters can convert solar panel DC power into AC power which can be directly input to the grid.
K-G05P1-EU-AM2(1).png)
3.6-6.2kW Single-Phase String Inverter
SUN-(3.6~6.2)K-G05LP1-EU-AM2
2 MPP trackers, Max. efficiency up to 97.5%.
Zero export application, VSG application.
Wide output voltage range.
Anti-PID function (optional).
Low start-up voltage of 80V.
K-G02P1-EU-AM2.png)
9-10.5kW Single-Phase String Inverter
SUNSYNK-(9~10.5)K-G02P1-EU-AM2
2 MPP trackers, Max. efficiency up to 97.7%.
String intelligent monitoring (optional).
