The Sunsynk website will be temporarily unavailable from Tuesday 5th May due to scheduled updates as we transition to an upgraded online platform.
Customer Support UK: +44 151 832 4300 | SA: +27 (0)10 1003589 | NL: +34 40 798 7136
Alternatively email support@sunsynk.com or get in touch via the Sunsynk Connect app.
High Voltage 3-Phase Hybrid Inverters
80kW
.png)
This multifunctional inverter integrates an inverter, solar charger, and battery charger, providing reliable power backup in a compact design. Its comprehensive LCD display allows for easy configuration and operation, enabling users to adjust battery charging, AC/solar charging, and input voltage settings based on specific needs.
.png)
80kW HV Three-Phase Hybrid Inverter
SUNSYNK-80K-SG02HP3-EU-EM6
100% unbalanced output, each phase.
AC couple to retrofit existing solar system.
Max. 10 pcs parallel for on-grid and off-grid operations, supporting multiple batteries in parallel.
Max. charging/discharging current of 160A.
High voltage battery, higher efficiency.
6 time periods for battery charging/discharging.
Supports storing energy from diesel generators.
