Public·369 members
External Meter for CT
Has anyone used the external meter for CT option. My CT is 600 watts out and I’ve seen a video of an external meter being used instead which I’d hope would fix the issue for me. It gives the option of 4 different meters in the inverter settings. I’m assuming the below is fine to use.
https://www.anymeters.co.uk/products/sdm230dr?variant=40177483481279&currency=GBP&gclid=EAIaIQobChMIiurl0fvm-QIVyrTtCh0tkw7pEAQYASABEgLODvD_BwE
peter.knapp
Aug 30, 2022
Ten meters away is fine. Just ensure you use twisted pair cable for the extension of the existing CT to the inverter. And make sure the existing CT is well twisted as they sometimes come a bit "loose". While it's possible your CT is faulty, every single one of these I've seen not tracking grid is when someone has used speaker cable or two core 0.75mm flat cable or similar ot extend the CT leads and it's picking up serious cross talk from the other cables nearby
