I had a great day out this week in Ireland, looking at a development site where we tested the wind turbine using the Sunsynk Hybrid...
tested the wind turbine using the Sunsynk Hybrid inverter, sunsynk operating system and platform at work to dream.
Few Hot Tips
Depending on the power of the wind turbine and the output load, you could consider using a designated Inverter to connect the turbine to the batteries, and a separate Inverter or Inverter is used to discharge the batteries.
Remember all the three-phase inverters have asymmetrical MPPT, so the more significant load on the wind profile or wind curve should be set on the MPPT1
The curve should start withMPPT2 and then switch in MPPT1
Don't forget to ensure that all battery cables are balanced.
We also used four diodes to join the MPPTs together. This allows a 16-point profile rather than eight steps.
I will try and produce a detailed training video on the wiring and programing.
6 October 2025
