Lynks 6kW
Lynks 6kW
Explore BenefitsThe Sunsynk Lynks Range is a compact single-phase hybrid inverter solution designed for reliable, scalable solar and battery storage across residential developments. Engineered for consistency across multiple installations, it enables fast and efficient deployment of complete solar energy systems. The Lynks Range simplifies installation and reduces on-site labour time, making it ideal for large-scale housing projects. Oversized MPPTs maximise energy yield from modern high-output solar panels, while compatibility with low-voltage batteries provides flexibility across a range of system designs. Supplied with an integrated data logger for real-time monitoring, the Lynks Range combines performance, simplicity and scalability to deliver a cost-effective hybrid inverter solution for modern residential energy systems.
| Description | Lynks 6kW 1P LV IP41 Whi |
| SKU / Model Number | SM6.0kWLLL |
| Power | 6kW |
| Phase(s) | Single Phase |
| Voltage Level | Low Voltage |
| IP Rating | IP41 |
| Gross Weight | 19.3kg |
| Net Weight | 16.1kg |
| Colour | White |
Benefits of Lynks 6kW
Plug and play installation
Simplified wiring and layout reduce installation time.
Reliable everyday performance
Consistent hybrid operation for residential systems and developments.
Compatible with Sunsynk’s full low-voltage battery range.
Maximised solar generation
Oversized MPPTs support modern high-output solar panels.
Scalable system design
Supports scalable batteries.
Cost-effective residential solution
Designed for cost-sensitive residential projects.
Explore Our Product Ranges
LP 12kW IP65
Inverter
Lynks 3.6kW
Single-Phase Hybrid Inverter
Lynks 8kW
