Lynks 3.6kW
Lynks 3.6kW
Explore BenefitsThe Sunsynk Lynks Range is a compact single-phase hybrid inverter solution designed for reliable, scalable solar and battery storage across residential developments. Engineered for consistency across multiple installations, it enables fast and efficient deployment of complete solar energy systems. The Lynks Range simplifies installation and reduces on-site labour time, making it ideal for large-scale housing projects. Oversized MPPTs maximise energy yield from modern high-output solar panels, while compatibility with low-voltage batteries provides flexibility across a range of system designs. Supplied with an integrated data logger for real-time monitoring, the Lynks Range combines performance, simplicity and scalability to deliver a cost-effective hybrid inverter solution for modern residential energy systems.
| Description | Lynks 3.6kW 1P LV IP41 Whi |
| SKU / Model Number | SM3.6kWLLL |
| Power | 3.6kW |
| Phase(s) | Single Phase |
| Voltage Level | Low Voltage |
| IP Rating | IP41 |
| Gross Weight | 12.0kg |
| Net Weight | 10.5kg |
| Colour | White |
Benefits of Lynks 3.6kW
Engineered for large-scale housing projects.
Designed for cost-sensitive residential projects.
Fast, Installer-Friendly Setup
Designed to simplify installation and commissioning of single-phase hybrid inverter systems across individual homes and large-scale residential developments.
Low Voltage Battery Ready
Compatible with Sunsynk’s full low-voltage battery range.
Maximised solar generation
Oversized MPPTs support modern high-output solar panels.
Scalable system design
Supports scalable batteries.
Explore Our Product Ranges
LP 12kW IP65
Inverter
Lynks 6kW
Inverter
Lynks 8kW
Single-Phase Hybrid Inverter
