Sunsynk Fault Codes
Public·25 members
Pavlo Prodanchuk
Pavlo Prodanchuk
constant F45 AC-UV-OverVolt_Fault code
Hi,
I have 6.8 system 16 panels with split on 2 strings 8 and 8. From the start of installation the system gives F45: AC_UV_OverVolt_Fault.
This could happen up to 10times a day in very sunny day. Loosk like its happening when the system has a lot of sunshine and generating maximum energy.
I checked settings and the max is looks like 253v but it never reach this number and stays around 251-252v maximum buts still triggering the fault.
Invertor is SYNK-5K-SG04LP1, software m3.3.8.6 / S 1.5.1.5 C E.4.3.8
Any idea how to fix it? I have similar setup in another house with 14 same panels and it never gives any trouble, the only difference i manage to found between the system is that the fault one showing flow to the battery which doesnt exist...
Unknown member
Apr 23, 2024
Unfortunately Sunsynk closed all my tickets and refer to the installer. Installer changed Over Voltage U settings from 253 to 269V but Sunsynk still giving a fault on 252v :(
