F56 Low voltage fault
Good day all,
I cureently have a 16Kw single phase inverter setup paired with a cyclone C10 10 kwh battery with a 2C rating
A mere 45 mins into load shedding I have the kow voltage error pop up, this is while the house runs on 1.2 KW
I cannot get the CAN BMS to work, so I have setup up to AGM settings with all the voltage parameters,
The inverter shows 0% 45 mins into load shedding and the battery SOC is sitting at 92% and 53.6 volts
What could be the issue?
Thank you so much for the help😊I really appreciate it, ill contact the suppliers tomorrw
