Solar panels not showing up
Hello,
I have the Sunsynk battery and inverter fitted to my solaredge panel system. But for some reason on the Sunsynk software it doesnt show the pannels doing anything. Can anyone help?
Regards
Michael McManus
Hello,
Regards
Michael McManus
Smart SolarEdge panels use Integrated Power Optimisers to improve the performance of the panels, particularly if you have a shading issue. None the less this should not cause an issue when connected to the Sunsynk inverter. However if the panels are connected to a separate inverter or are isung microinverters, you will not see the panels on the Sunsynk inverter :-)
