Public·391 members
440W Ja Solar panels on an 8kW sunsynk
I want to install 19x 440W Ja Solar panels , with a Isc of 10.44A and Imp of 9.97A on a 8kW sunsunk. There would be 2 strings of 6 panels on the one MPPT, and 1 string of 7 panels on the second MPPT ( due to 2 different orientations). The sunsunk's max MPPT input is 18A. Will the 2x 9.97A Imp on one MPPT cause failure/trips or will it work ok? Will the sunsynk just adjust the Amps lower to 18A max and you then lose some efficiency of the panels?
Werner Venter
Werner Venter
Sep 10, 2020
Thanks. By calculation the Voc ended up at 526V (Coldest day, etc) if I put 10 in a row so I was not prepared to take the risk to go over the 500V. I have seen on one string with 4 panels just over 200V on our coldest days. That means it can go over 500V with 10 panels.
