Public·327 members
Inverter running at 52 Hz when Auxilary port selected to input
When Auxilary port is selected to input the Hz changes to 52, if I select it back to output it changes back to 50.
Our clocks are gaining time.
System:-
2 x 8K SG01LP1-EU COMM:e424-MCU:5374 in parallel
36 x JA 540w panels
9 on each MPPT on each inverter
14 x PylonTech 4.8Kw Batteries
Why is this, how to correct it?
Thanks David
jacekowski
Mar 20, 2025
If you configure your system properly the inverter should not have a need to limit power and should deliver stable 50Hz.
