Public·371 members
Load readings issue during export with Solar Assistant
Is there anyone else using Solar Assistant who is getting strange Load readings when exporting? On my paralleled 3.6kw inverters the Load always drops to around 200W in Solar Assistant when I export whereas the SS native app shows the load slightly increase (to be expected)
I only get this behaviour when selling to grid
ijhammo
22 de abr. de 2024
issue resolve. Its a setting in Solar Assistant - you need to make sure you select CT installed in advanced settings if you have one installed
