system mode to charge batteries from grid
his guys ,
i have a 8KW sunsynk system with 2X 4.8kw lithiumion batteries . i wanted to charge the batteries from grid from 21:00 till 00:00. at 21:00 my batteries were at around 6%. but it didnt even charge from the grid carried on using the grid for the load . see below the settings i did . can anyone tell me if this is correct or what i shud have tried .
below is the 24hr chart from solarman smart for the time period
any advice and guidence would be appreciated
Hi thnx for the clarity. yes i am using SHOTO batteries the sunsynk manual says you have to use voltage based charge settings. i will reset the system mode and check again .
