8kw inverter - is 240Vac out possible
Is it possable to set the inverter output to 240Vac?
I have a 8kW Sunsynk and during utility fail i get 230Vac from the inverter, no problem here.
Where i live, South Africa, my grid supply is between 241Vac and 245Vac.
Is it possable to set the inverter out Voltage to 240Vac, or is 230Vac a hardware restriction?
I would like to stay as close to the "Normal" grid voltage as possible. Grid voltage don't just drop 10+ Volts during normal operation, it does fluctuate, but over a few seconds not instant. Having the inverter voltage close to grid voltage does seems to be the correct way and it will reduce transient spikes when the grid goes off, in our case loadshedding. Electronics don't like sudden changes.
