Public·405 members
MikKentMikKent
Strange loss of juice
So I have the 5.5 unit up and running but every now and again there is a phantom drain. Last night the use in the house went from 0.62kwh to sometimes 2.9 but staying around 2.2 this happened as the battery depleted. I have checked the amps being used from the grid and using about 2.8 amps currently. There in nothing on other than the background use and daily use but we are not using 2kwph constantly as the graph shows in fact the house should be background at about 22:00 as that is when we went to bed last night. I have attached teh use as far as octopus is seeing and the numbers for octopus seem about right, charge battery between 11:30 and 05:30, also how water charge around 03:30 Anyone have any ideas as the battery is getting drained and going somewhere but not in my house!!!! This has happened a few times now. I have checked the ct connection, powered off the unit and its still doing the same.
thanks for reading.
giles1234
2023년 5월 16일
Check your system mode settings. I bet the power is set to 5000 during this time? Whether "ticked" or not, this has an effect. Reduce to 10w and then check to see if there is still this massive draw. It looks to me that your batteries are flat and they are charging from the grid.
