Public·327 members
NEW INSTALL LIFELYNK
Looking at installing a Lifeliynk S all in one battery inverter a upgrade from a small 800w Microinverter, I have two JA Solar 405 watt panells already on the roof, looking to increase to 6 panels in series to reach the inverter start voltage of 150v, inverter max current 12A, my panells rated at max power 12.98A, short circuit 13.87A, voltage VOC 37.23v would the current cause any problem to this single mppt inverter?
I’m aware some inverters will clip the current to the max allowed, is this the case with this inverter? and I am also aware the voltage should not be exceeded.
Any help would be appreciated.
Oct 21, 2024
The total Voc is the most important value. The current will be limited by the MMPT controller.
