Public·394 members
Grid charge multiple timers
Could any help me to put 3 different grid charge times on my battery I have done one but as there are 6 potential timers it’s a little confusing
I need 10pm to midnight then I need 4am until 7am and then 1pm to 4pm
globetrotter
Mar 22, 2025
00:00 04:00 20% No grid charge tick
04:00 07:00 80% Tick grid charge
07:00 13:00 20% No grid charge tick
13:00 16:00 80% Tick grid charge
16:00 22:00 20% No grid charge tick
22:00 00:00 80% Tick grid charge
From the above for the periods with NO grid charge tick the battery will discharge, in this case to 20%
For the periods with grid charge ticked it will charge the battery from the grid, in this case to 80%
I am advised there should be no gaps in the times and better not to go through midnight.
The power entered for the charging period is what is going in to the battery. I have mine set to 2000 which is around 36 amps (for 7 hours). It is good practice to chose a charge rate which uses most of the available time rather than bashing the maximum in at the start.
Oh and tick Use Timer!
