Public·385 members
Battery export not working
Sell first seems to be broken for me and I have no idea why.
It goes from this in zero export and priority load, where its working normally
Edit: I should also point out that solar export is fine and has been exporting to grid at 5kW today.
To this if I check selling first which I believe should start exporting from the battery. However here it removes the unessential loads and apparently is getting 400W from the essential loads (which nothing is connected to!). It also actually stops discharging the battery rather than exporting it, i'm not really sure what it's intending to do...
Has anyone else been having issues? At the moment I can't export anything from the battery which is a bit of an issue as I'm on Octopus Flux....
james_vallance
Mar 30, 2023
Sure, here are the settings that I normally run and everything works as expected. To switch to trying to export from battery I unticked zero export and priotity load (i've also tried unticking everything) and I get the behaviour shown above.
