Public·405 members
545W Canadian panels on 5kW Sunsynk inverter
I am looking at the 5kW Sunsynk and was working out how many panels of 545W will fit in a string. I plan on getting 10 panels, but if my calculations is correct, it looks like I will only be able to do 9 in series for the Voc to be under 450V.
If I do 5 in series on 1 MPPT and other 5 in series on other MPPT, looks like I get the same performance, but I am worried that my working Voltage which will be around +- 205V might be to low then for the inverter? The VOC will be around +-250V then.
So what is the best amount of panels of 545W and how do I connect them for the best performance on the Sunsynk 5kW inverter?
Thank you very much
jacekowski
Feb 14, 2023
No point in installing those fuses. The panels have short circuit current rating of 13.9A (and unless in direct sunlight in middle of the day you will not get that sort of current from them). Typical 12A fuse at 13.9A will take (depending on exact type) somewhere between 3-ish hrs (fast blow) to infinity hours to blow (standard fuses).
