Public·330 members
Sunsynk connect app display sunsynk 5.32 battery
Hi all
I recently had a sunsynk 5kva inverter with a sunsynk battery installed. I set up the app. The inverter and the gateway is displayed under the equipment tab. The battery does not reflect there and it doesn't seem like I can add it. Is the battery supposed to reflect under the equipment tab? If yes, how do I get it added there?
Nikolay Nenchev
Jul 10, 2023
Hi,
It is there. Click on Equipment, then select your inverter, then battery there
, and you will see it.
