Public·391 members
Export on 3 x 5kw inverters setup as 3 phase.
I have a client wanting to install 3 x 5kw inverters in a 3 phase configuration. He would like to export excess solar power when available however at times he wants to only export on 2 of the 3 phases as he has 3 x bi-directional meters on his grid supply. Is it possible to turn on the export function on 2 of the 3 inverters and leave one off... will the export function work this way or does it need to be balanced?
steve.morris9
steve.morris9
11 feb 2023
Regardless if the system is capable of exporting an unbalanced load, (I don’t know myself) will your local DNO accept an unbalanced load being exported.
