No-load self-consumption.
Hello The Sunsynk looks not bad at all. One thing I can't find is the no-load self-consumption numbers. Looking for 8 or 5kw. Thanks in advance
Jun 22, 2023
When there is no load it is between 50W and 70W. As this is a bidirectional hybrid inverter it will use a little more than just battery inverters like the Victron which uses around 11W
This is why the there is a Low power Mode which basically allow you to force the inverter to hibernate when the Low Batt value is reached. The inverter will the operate normally when solar is available. If you use this setting you must also ensure that the SOC on the System Mode/System1 has to be lower than the Low Batt value.
