AC tripping on the inverter
I have noticed that sometimes the AC light on the inverter goes off and comes back sometimes like a couple of seconds and sometimes abt 30 Dec or so..... there is no power failure in my area when it happens and sometimes it keeps on happening five or six times and then it stops . i dont have any power interruptions while it happens. i picked it up when i noticed the relay on the oven cuts the power to it and the oven goes to stand-by mode. any advice on this would be appreciated
I am no expert, but it sounds like your inverter is feeding back into the grid, causing your electricity meter to trip. It could be that the CT coil is not correctly installed, or it might be correct but your electricity meter could be particularly sensitive. It could perhaps also just be your settings that need adjustment. I have seen multiple posts around this on the Powerforum site. You can perhaps check out this post: https://powerforum.co.za/topic/9717-prepaid-meter-tripping-for-a-few-seconds/
I would also suggest that you post your question on powerforum, because there are many knowledgeable Sunsynk users and installers that actively post on there.
