Public·382 members
DNO Approval
Hi just have my DNO I am allowed my 10kw array, 2 x 5kw Sunsynk inverters and 16kw
battery with an export limit of 5kw. They have excepted the inverter capping
the limit. I am quite pleased about this....outcome....phew!!
CF_UK
May 22, 2023
How have you capped the export to 5kWh? Even with inverters in parallel as master/slave, configuration options aren't shared/global so are you just going to split it and set each inverter to 2500w? I have 2x 5K iinverters in parallel too and couldnt find a way around it.
