SUNSYNK-8K-SG01LP1 vs SYNK-8K-SG05LP1
I am in South Africa - if that matters.
I want to replace my existing SMA inverter with 2 of the 8 Kw Sunsynk inverters.
What are the differences for me as a user, between SUNSYNK-8K-SG01LP1 and SYNK-8K-SG05LP1?
Any explanation or advice would be greatly appreciated.
The reason I want to go fro 2 of 8 Kw inverters and not the 16 Kw is purely for redundancy.
Thanking in advance
I have never used ferrite rings. The reason why you may want to use them is to try and reduce any interference that the inverter may cause, for example if you are a HAM operator.
